Missing Effect Items
Darcon64
Post by Darcon64 » Wed Jan 29, 2020 1:00 pm
Downloaded V2.3.3. In Effect Tab, at least the following are missing: Studio Fade out; Adjustable Fade; and in particular Filter Curve and Graphic EQ. See attachment. Any solution?
Audacity Effect menu.png (40.86 KiB) Viewed 280 times
Audacity Version.png (50.85 KiB) Viewed 280 times
Re: Missing Effect Items
Post by steve » Wed Jan 29, 2020 1:11 pm
I think you will need to reset Audacity.
If you are on 64-bit Windows 10, shut down Audacity then open up:
Code: Select all
Users\<username>\AppData\Roaming\audacity\
in the Windows file browser (File Explorer) and delete the three files:
Code: Select all
audacity.cfg
pluginregistry.cfg
pluginsettings.cfg
Then restart Audacity. Those three files will be automatically recreated with default factory settings.
Darcon64
Post by Darcon64 » Wed Jan 29, 2020 1:53 pm
Thanks. That has solved the problem.
