Darn did I just waste $30 on a WAVES VST Plugin ?
My Computer says it’s a X86 , Now the plug I bought is x64 , I’m reading audacity only takes x32 ?
the plug in is apparently installed on my laptop , so what the heck does x86 mean ?
If your Windows computer has a 64-bit Operating System it can run both 32-bit and 64-bit software.
But a 64-bit version of Audacity is not yet available for Windows.
Its competitor OCENaudio has 64-bit version which may be able to run your 64-bit waves plugin,
but only if you have a 64-bit Windows Operating System.
AH I just did Factory Reset of my LAPTOP ,
My Roaming App Folder isn’t working right ,
I think all WAVES plugins come with both 64 AND 32 Version , somehow its not choosing the 32 ,
my other waves were just fine.
I figure this has to be the case , Otherwise it would of never installed on my LAPTOP Correct ?
Ouch, that’s a drastic measure.
The recent versions of their plugins are only available in 64-bit, see …
https://www.waves.com/support/tech-specs/system-requirements#plugins|version-11
If you have a 64-bit Windows Operating System, 64-bit plugins can be installed, but 32-bit Audacity won’t see them.
64-bit Audio editors, (like OCENaudio), may be able to see & use 64-bit plug-ins.
In the waves plugin tech-specs there is a list of the software they are known to work with,
… https ://www.waves.com/support/tech-specs/supported-hosts , (Audacity is not mentioned).
Argh yes because when I installed my other 2 apps it was before the update with WAVES 11.
Also the last time this also all worked was with installing with Audacity it was during like August 2018 or 2019 ?
has their also been a new audacity release since then too ?
is their a audacity from 2018 ava ?
I posted this Help topic back in April 2018 , the method that worked is not this time around ,
Was AUDACITY a different build in 2018?
https://forum.audacityteam.org/t/waves-vst-plugins-not-showing-up-on-audacity/48799/1
Don’t tell me WAVES just made a big enough change to my stuff headed to the trash can
OK Good News I can roll back to WAVES 10 , I did spot a GREGG WELLS X32 dll in the list of FAILED Plugs In in the disabled list in AUDACITY
I tried installing , I must be doing something wrong of course ,
Oh yeah that’s another thing how do I refresh the list ?
all the stuff is no longer installed but yet some how all the stuff is showing on the disable list.
I even uninstalled audacity and it showed up
still on the disabled list , very weird.
By the way I just installed AUDACITY 2.2.2
that’s the one I had right before I factory reset my pc , Imagine it’s the same one I was referring to in the help topic I referred to.
Unfortunately there’s not yet any automated way to do that. It has to be done by manually removing the two configuration files:
You will find those files in the hidden folder:
Users**\AppData\Roaming\audacity**
(“” is your computer log-in name)
Ensure that you shut down Audacity before deleting those files.
HEY YO !
looks like I am going to be fine ,
I seriously just threw everything in the AUDACITY Plugins In Folder ,
It eventfully connected itself to what it needed LOL.
MADNESS Works !
Thanks Everyone !
