Update Failure
Nevv
Update Failure
Post by Nevv » Mon Jan 13, 2020 1:56 am
Why can't I update my 1.3 Audacity... When I try, I get a message "Setup was unable to create a directory" "Error 5: Access is denied".
Re: Update Failure
Post by steve » Mon Jan 13, 2020 9:40 am
Which version of Windows?
Nevv
Re: Update Failure
Post by Nevv » Mon Jan 13, 2020 11:46 am
Windows 7 Home Premium
Re: Update Failure
Post by steve » Mon Jan 13, 2020 12:19 pm
  1. Completely remove your current version of Audacity (uninstall, then delete the Audacity folder from the Programs directory).
  2. Download Audacity 2.3.3 by following the links on the Audacity website: https://www.audacityteam.org/download/windows/
    You need the "Audacity 2.3.3 installer"
  3. Run the installer and enter your admin password when prompted.
    Watch out for the option to "Reset Preferences" and ensure that option is selected.
  4. On first run, confirm that you wish to reset Preferences.
Nevv
Re: Update Failure
Post by Nevv » Tue Jan 14, 2020 3:01 am
Audacity is uninstalled. How do I go about finding the Audacity folder from the Programs directory? Where is the program directory?
Nevv
Re: Update Failure
Post by Nevv » Tue Jan 14, 2020 3:23 am
I tried installing 2.3.3 after uninstalling... same message came up.
Nevv
Re: Update Failure
Post by Nevv » Tue Jan 14, 2020 3:33 am
The following message comes up... Setup was unable to create a directory C:\Users\Sheppard\AppData\Local\Temp\is-DUG0G\tmp
waxcylinder
Re: Update Failure
Post by waxcylinder » Tue Jan 14, 2020 10:04 am
You do know, I hope, that today 14Jan2020 is the day that Microsft stops support for Windows 7 and declares EOL
See: https://support.microsoft.com/en-gb/hel ... ry-14-2020
As far as we know the latest Audacity (2.3.3) still runs on Windows 7 - but we no longer support it on that OS version,
Re: Update Failure
Post by steve » Tue Jan 14, 2020 10:49 am
Are you logged in as "Sheppard"?
Ivalogic
Re: Update Failure
Post by Ivalogic » Tue Jan 14, 2020 3:04 pm
This reminds me when I erased a "Temp" folder, when it was automatically created back, it was with a different permissions setting; I had to manually readjust those settings to be able to install and uninstall some programs.
