Double Click - can I disable it?!
philchenevert
Post by philchenevert » Thu Jan 02, 2020 3:33 am
Windows 10 audacity 2.3.0
When working inside a track to edit it, accidentally double clicking frustratingly moves me back to the start, completely making me lose my place in a long track. It is much to sensitive and happens frequently. Is there any way to disable whatever this is? I have searched and looked but can find no way of doing it in personalizing keys. It is a double left mouse click that does it and I would love to disable, stop or eliminate it. :?: thanks.
Re: Double Click - can I disable it?!
Post by steve » Thu Jan 02, 2020 10:00 am
Double click on an audio clip selects the clip. For mouse users, this is usually the quickest and most convenient way to select an audio clip.
Mouse button bindings are not currently configurable.
Common causes of accidental double clicks include:
  • Low batteries (wireless mouse)
  • Mouse button switches wearing out
  • Damaged lead (wired mouse)
philchenevert
Post by philchenevert » Thu Jan 02, 2020 7:34 pm
Thank you Steve. Since I cannot configure the mouse buttons yet, I will replace the battery in my mouse and perhaps try replacing it to see if that helps! :D :D
Post by steve » Thu Jan 02, 2020 9:32 pm
Fingers crossed :D
