hi recently I had an issue with my turntable and speakers..as I was recording into the computer though my speakers I heard no music though the speakers..i wanted to heard the music so I can moniter the music..so to correct this I went into edit then recording then I enabled " software
playthough of input".its fixed..i hope this helps someone besides yours truly
lenny
an audicity tip
paulspecht
