How to export multiple tracks without all of them getting the same length?
Boi Social
Post by Boi Social » Wed Dec 11, 2019 5:07 pm
I searched this forum and Google without any results. The only thing I could find was someone looking to find the opposite of what I’m trying to do...?
Anyway, here’s the problem and question:
Are use a recorder to make memos of different lengths and quality. I started using audacity so I can quickly compress EQ normalize multiple files etc.
I made a macro that can do this but I am finding that when exporting multiple files all of them get the same length as the audio with the longest time duration, which gives me excess silence...
Is there a way to change this behavior in audacity or is this the only way to export multiple files?
Re: How to export multiple tracks without all of them getting the same length?
Post by steve » Wed Dec 11, 2019 5:39 pm
Macros will generally export the track as whatever length it is. Without knowing exactly what you are doing, I can't guess at why that's not happening for you.
Boi Social
Post by Boi Social » Thu Dec 12, 2019 8:08 am
Wow!
That was real quick :D
Ok here's a step by step walkthrough:
1. I open Audacity (version 2.30)
2. I drag and drop multiple audio files into the "playlist" and let them load
3. I press ctrl-A and select my custom macro (effects in order = >Stereo to Mono >Find Clipping >Compressor >Limiter >HPF >EQ >Normalize >Click Removal >Truncate Silence >END) and let it apply the effects.
4. After letting the effects process i go to export and select "export multiple", choose the same folder and overwrite existing files and then press export. And that's it
The result being that all the files get the exact same length as the one with the longest duration :O
Was this enough info?
I use windows 10 64bit
Post by steve » Thu Dec 12, 2019 10:03 am
The current version of Audacity is 2.3.3. It is available (free) via the Audacity website: https://www.audacityteam.org/download/windows/
I would strongly advise that you don't directly overwrite the original files. If anything goes wrong, you could permanently lose the recordings. Much better to export to a new folder. If you don't want your original, unprocessed files any more, you can delete them after you have checked that your modified versions are correct. This is a little more work, but a much safer workflow.
If you Export Multiple "based on Tracks", then each track should export as the correct length. If that doesn't happen, then it could be a bug in your old version of Audacity.
Boi Social
Post by Boi Social » Thu Dec 12, 2019 3:56 pm
Thanks and great tips :D
Where can i find this "based on tracks" option..??
Boi Social
Post by Boi Social » Thu Dec 12, 2019 4:00 pm
Actually scratch the previous post!
I noticed that this only happens AFTER using my custom macro. The macro seems to fill in the silence... But i don't know why or how to quickly remove it..? Any suggestions??
Post by steve » Thu Dec 12, 2019 4:21 pm
In the Export Multiple dialog: https://manual.audacityteam.org/man/exp ... tiple.html
What settings do you have in "Edit menu > Preferences > Quality"?
Boi Social
Post by Boi Social » Thu Dec 12, 2019 5:20 pm
[/quote]
Ok...
SO I tested a copy of macro and each time after processing removing an effect from the chain starting at the end to the beginning...
Only after removed the Limiter it seemed that there was NO silence added to the end of the audio...
SO apparently there's some kind of bug (or maybe it's intentional?) that makes all the effects that come AFTER the compressor (limiter>hpf>eq etc) effect, add silence to match the longest audio...?
weird...
Post by steve » Thu Dec 12, 2019 5:38 pm
The Limiter effect is a "Nyquist" plug-in.
A limitation of Nyquist plug-ins is that when they process empty space in a track, they return silence where the empty space was, so if the selection is longer than the track, then the selected part of the track after the audio ends, will be replaced with silence.
I would have expected "Truncate Silence" to remove that added silence.
What format are the files that you are importing?
Boi Social
Post by Boi Social » Thu Dec 12, 2019 8:33 pm
It's not just the limiter that does this... It almost seems like it has more to do with doing CTRL A because when I only select one track it neatly leaves the end as is... :S
I'm using MP3 files :)
