vertical spacing of tracks not saved?
I notice with V2.3.3 running on win-7 pro that I can't save changes in vertical track spacing anymore? Songs all load now with full size height for every track no matter how many I'm using. I'm pretty sure It used to remember all my screen layouts? Am I missing a setting option in the new version or something else? Thanks!
Re: vertical spacing of tracks not saved?
Maybe the new version has forgotten your preference for: "auto-fit track height"
Thanks for the tip, I think that did it.
Well, worked with it for awhile now, no luck. I swear I used to be able to save track heights with project but now it's either all compressed with "fit height" set or default has huge tracks that need re-sizing or compressing. I usually have a few tracks compressed with other full open for editing and others somewhere in between. Have to re-format every time I open the project, either to compress or expand. For future issues, PLEASE address this for a REAL time saving feature. Thanks!
You could, but there's a bug in Audacity 2.3.3. It has been fixed for the next release (Audacity 2.4.0 is scheduled for release around April).
