Audacity with Xone 96 Mixer - No or Very Low Signal in Audacity
Davis331
Re: Audacity with Xone 96 Mixer - No or Very Low Signal in Audacity
Post by Davis331 » Thu Feb 04, 2021 7:29 am
andre199017 wrote:
Tue Nov 26, 2019 5:41 pm
Windows 10
Audacity 2.3.3
Hi guys,
I recently purchased a Xone 96 Mixer from Allen & Heath and have been trying to record my sets in Audacity, but sadly I am having issues.
The peak meters on the mixer are alive (boucning into the greens and reds), plus Traktor software is able to record the output from the mixer with no issues, but sadly no life in Audacity.
My audio choices are:
MME
Microphone: Line (Xone 96 USB 1), 2 Stereo Recording Channel
Speakers: I have tried both the Xone 96 USB choice, as well as the default laptop speakers Conexant SmartAudio
My sample rate is at 44100Hz.
I hit record and see nothing on the waveform: https://imgur.com/a/D4kKjMK
Life in the Traktor recording meters seen here: https://snipboard.io/myxhDq.jpg
Appreciate any help.
I endeavored to change the driver chose however then the blender doesn't seem to work.
Falc0nhawk
Post by Falc0nhawk » Thu Feb 04, 2021 8:13 am
Thanks for the help.
I’m using a Mac so I think this complicates matters?
I contacted Allen & Heath as well and sent his reply.
he Xone:96 is fully supported on Mac OS 10.15 Big sur (currently Intel-based machines only)
We have had a few reports of this, plus we have tested it out in-house and got the same result. It's basically down to how the Audacity software manages core-audio compliant devices. As to why it works that way, you would need to consult with the software developers. I would like to add that there is nothing wrong with the mixer. We do know that the Audactiy software works fine with the ASIO driver that we have available for Windows. So if you are married to that particular piece of software and have access to a PC, maybe try going down that route!?
A workaround for Audactiy on Mac would be to use stereo input one as your record bus send. this will only work so long as you are not using channel 1 'line' input for anything. The idea would be to connect from the RCA record output, to channel 1 'line' in, then make sure the USB routing switch is set to 'LN'. The signal will then be sent directly to USB streams channels 1&2, which are the only two channels that seem to work in Audacity on Mac (core-audio). Finally, make sure channel 1 input selector is not set to LN with the fader up! As this would cause a feedback loop.
Using up an input Chanel isn’t ideal. At least it’s a reply.
jademan
Forum Crew
Post by jademan » Thu Feb 04, 2021 12:57 pm
No. You do not need ASIO for Mac.
So you have that. Also check permissions. See this post: viewtopic.php?p=363418#p363418
And here: https://forum.djtechtools.com/showthread.php?t=96475
Are you on Audacity 2.4.2 ?
And what steve says:
steve wrote:
Tue Feb 02, 2021 10:36 am
Does the Xone 96 mixer show up in the Windows Sound control panel?
If so, is it enabled, and do you see the green meter in the Recording tab respond to input from the Xone?
I hope this helps. :D
Falc0nhawk
Post by Falc0nhawk » Thu Feb 04, 2021 1:04 pm
I had already checked the microphone settings, they are all set up correctly.
I’m using the most up to date Audacity.
