Upgrading from older beta software on computer.
Re: Upgrading from older beta software on computer.
Post by steve » Thu Nov 21, 2019 2:59 pm
snapshot2020 wrote:
Thu Nov 21, 2019 2:57 pm
Is there a simple to switch the recorded tracks i play?
The tracks have "Solo" and "Mute" buttons (https://manual.audacityteam.org/man/tra ... scale.html)
Is that what you meant?
snapshot2020
Post by snapshot2020 » Thu Nov 21, 2019 3:13 pm
Yes that was very helpful, will takeme some time to fully understand it's use.
And again thank you for the quick replies and your deep understanding of how the software works.
