I am using Audacity ver 2.1.3 and Windows 10.
Just a quick question about selecting a large (hour long) section of the audio waveform for deletion. After recording a 3 hour long audio file with Audacity, I wanted to highlight and delete the last hour of the recording. Highlighting an hour long section of the wave-form by left-clicking and dragging the mouse takes "forever". Is there a faster way? I want to highlight the hour-long section of audio so that I can delete it. How can I quickly highlight a section of that length?
Thanks,
Carl Lewandowski
Selecting a long waveform quickly
zpntenergy
Re: Selecting a long waveform quickly
There are several ways to do that. Here's two:
1) Click where you want the selection to start
2) Zoom out to fit the entire project ("Ctrl + F", but also see: https://manual.audacityteam.org/man/zooming.html)
3) Hold down the shift key and click and drag the selection from the cursor position to the end of the track.
2) "Shift + End".
2) "Shift + End".
zpntenergy
Thank you,
Carl
Carl
