Any idea what is causing this?
TheRhysWyrill
Post by TheRhysWyrill » Sat Nov 16, 2019 9:47 pm
Hi everyone,
I was wondering if anyone has any idea what is causing this robotic hum with my microphone?
It only lasts for about 5-10 seconds and the audio is being recording using a usb audio mixer and i've tried everything to figure out the cause to no result, any help would be much appreciated.
Thanks
- Rhys
Audio Buzzing.wav
The issue described.
(952.08 KiB) Downloaded 4 times
Trebor
Re: Any idea what is causing this?
Post by Trebor » Sat Nov 16, 2019 10:05 pm
Softwares can fight over control of sound. One retains control but is interrupted at regular intervals.
When that happens it can cause regular pulses like you have, ( 10ms apart if that's any help ).
TheRhysWyrill
Post by TheRhysWyrill » Sat Nov 16, 2019 10:10 pm
So it sounds like a software conflict?
How would i go about fixing this issue, if there is a fix?
Thanks, much appreciated
- Rhys
Trebor
Post by Trebor » Sat Nov 16, 2019 10:46 pm
Yes.
There is an "exclusive mode" in Windows: so only one program has control of the mic ...
I've never had to use it myself though, so I'm not familiar with it :? ,
( I would try all possible permutations of the 2 "exclusive mode" tick boxes ).
Can also try giving Audacity higher CPU priority so it is less likely to be interrupted by other software.
TheRhysWyrill
Post by TheRhysWyrill » Sat Nov 16, 2019 10:51 pm
Yes.
I've never had to use it myself though, so I'm not familiar with it :? .
Alright i'll give that a go and see if that fixes the issue (fingers crossed).
Thanks for the help!
-Rhys
