Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
8bit_coder
- Operating System: Windows 8 or 8.1
Post
by 8bit_coder » Sat Oct 26, 2019 5:21 am
Ah, that makes more sense. Well, I've decided to make a nyquist plugin out of it and this is my code so far:
Code: Select all
;nyquist plug-in
;version 3
;type process
;preview linear
;name "aPWM"
;action "Applying PWM"
;author "me"
;copyright "No copyright"
;control smp "Sample Bias" int "1-1000" 1 1 1000
;control htz "Carrier Frequency" int "1-20480000" 1 1 20480000
(setf bias (snd-avg *track* smp smp op-average))
(osc-pulse htz bias)
however, whatever I set in smp just ends up being the output, and debug doesn't do any help either. I'm planning on making it automatically calculate a reasonable carrier frequency and sample bias.
- Site Admin
Post
by steve » Sat Oct 26, 2019 10:45 am
It needs to be a "version 4" plug-in.
There were some important changes between versions 3 and 4. The biggest one being that in version 3 and earlier, the selected sound was passed from Audacity to Nyquist as the variable "S". In version 4, the sound is passed from Audacity to Nyquist as the variable *track*.
Change the second line to:
