Audacity stops recording after about six seconds. [solved]
CarlosMurray
Re: Audacity stops recording after about six seconds. [solved]
Post by CarlosMurray » Thu Oct 03, 2019 4:22 pm
Thanks for you suggestions and help. All seems to be work now.
Post by kozikowski » Thu Oct 03, 2019 4:32 pm
How did you get there? This is a forum. Users helping each other.
CarlosMurray
Post by CarlosMurray » Fri Oct 04, 2019 8:25 pm
I received the dialog window with 'other application may be competing for resources' and I checked the
"Sound Activated Recording" box that was presented.
Yes, that was your first suggestion!
Thanks again.
