Windows 10, 1903
If I record a woman speaking one word and put it on Audacity, how can I make that in to a 10-second duplicate, and keep the same pitch, without it sounding like the same word spoken 10 times in a row?
stretching out a 1-second word for 10 seconds?
nelsonkane
Re: stretching out a 1-second word for 10 seconds?
Not really possible, sadly... You'll have to get that word recorded 10 times. Sadly you can't alter a voice and it's intonations without changing something such as the formant or pitch or just re-recording it so you get the desired result!
If you want this as an "effect", rather than someone actually talking very slowly, try these three effects (they each produce a different kind of effect):
https://manual.audacityteam.org/man/change_tempo.html (try both the HQ and non-HQ settings)
https://manual.audacityteam.org/man/change_speed.html (literally "slows down" the selected audio)
https://manual.audacityteam.org/man/paulstretch.html (really cool effect, but not at all "natural" sounding)
nelsonkane
Thanks, I'll give it a try!steve wrote: ↑Fri Sep 27, 2019 12:44 pmIf you want this as an "effect", rather than someone actually talking very slowly, try these three effects (they each produce a different kind of effect):
