Hi to all,
Please can somebody tell me where I have to put the Theme folder and ImageCache.png file in Portable Audacity?
I have tried in several paths without luck.
Thank you in advance for your help.
Kind Regards,
Elena
Question, where I put the ImageCache.png in Portable Version?
ElenaLauder
