Does this happend to others?
Let me know if this happends as well or only just me
Audacity stops responding while replacing a ogg audio 2.3.2
Re: Audacity stops responding while replacing a ogg audio 2.3.2
Can you explain EXACTY what you are doing? And, what do you mean by "replacing"? What are you actually trying to do?
So basically i was trying to replace the regular minecraft sounds (which i made it myself) when i do the audio and try to replace it, audacity crashes when i tried to export an ogg file, could be something.
