Windows 10 Home
Audacity 2.3.2
I had to reinstall Audacity and I now have an issue with Normalizing. I use the program to create music CD's. When I entered a song it would automatically check for DC offset and Normalize the track. Now I have to do each song manually.
Can anyone guide me as to how to get my old setting back?
Thank you.
Dave
Normalize
Re: Normalize
I don't think there's a way to apply an effect automatically when you open a file with Audacity... You can write a macro to do things automatically but I'm not sure if that would help you. (I've never used macros.)When I entered a song it would automatically check for DC offset and Normalize the track. Now I have to do each song manually.
You can use Audacity to record music and edit files in preparation for making a CD but Audacity doesn't burn CDs.I use the program to create music CD's.
And... Normalization doesn't necessarily match the perceived volume so it's not always the best procedure. There are tools for measuring/matching perceived volume but for a handful of tracks on a CD it's usually done by-ear. Typically you'd normalize all of the tracks individually, then if they don't sound equally-loud choose the quietest-sounding one as your reference and adjust the others down to match (by ear).
