Hi, I've been working on a recording all day and have hit the save button at the end and closed down. I've just gone to re-open the file and the screen comes up
File name "is an Audacity Project File. Use the file>open command to open Audacity Projects.
I've used this command and it still comes up with the same error. Can someone please help me!?
File open error
