windows 10 audacity 2.3.2
recording ok when using input = reg output = reg speakers
when I switch to Bluetooth to listen in another room while recording
input and output go silent
finally got input to start recording again but still no sound output with Bluetooth ??????
anybody had the same problem
bluetooth playback while recording
