Audacity is "stuck" at zero and won't record
mark_macrae_
I am having a very frustrating issue with Audacity.
It was working perfectly until yesterday.
I am working on a multi-track recording and want to add the piano track. I add a new mono track, hit record and the red "record head" just is stuck at zero and won't budge. I don't get any playback of other tracks. Nothing. When I stop the recording I sometimes get a cryptic message about latency and other times, no error message at all. But still nothing has recorded.
I tried monitoring the sound and it's working... I couldn't figure it out so I started a new project and hit record. It works perfectly recording the piano.
I go back to the original project. Still not working.
Then I started a new project and created a click track (rythym track) before I added a second track and hit record. STUCK!! Not working again.
It will record the piano only if there are no other tracks recorded... But I never had this problem before.
I have shut down the computer several times. No difference.
I am using a Roland Rubix 22 USB Audio Interface.
What is going on???
What is going on???
Re: Audacity is "stuck" at zero and won't record
Are you recording a real (acoustic) piano with microphones?
What are your settings in the device toolbar?
Which version of Audacity (look in "Help menu > About Audacity").
mark_macrae_
I am recording from a Roland electric piano via patch cable to the Roland rubix.
Windows 10 and just upgraded from audacity 2.2.1 to the latest 2.3.2 to try and fix the issue but no luck.
mark_macrae_
Oh and i out device is the rubix 22. Output I have tried all three settings, headphone, Microsoft mapper and rubix. Makes no difference to this problem it seems. Rubix gives me cleanest output though.
Try setting the "host" to "MME" in the device toolbar, then set the recording and playback devices to the Roland.
mark_macrae_
It is set to MME. Sorry, didn't mention that setting. I have now tried changing it to the two windows settings as well, but still no charge.
Look in "Transport menu > Transport Options" and ensure that "Sound Activated Recording" is turned off (not selected).
mark_macrae_
Yes I had already checked that setting and it is not on.
Shut down Audacity.
Power down the computer (completely).
Check the USB cable is securely plugged in at both ends.
Restart and try again.
mark_macrae_
Have tried that multiple times but doesn't help.
It will record just fine for one track.
When I add a second track, that's when it gets stuck.
