I have created a project on audacity, and when I tried to export, the process just stopped in the middle. The following is what happened:
1. I clicked file
2. Clicked export
3. Export as MP3
4. Clicked OK
5. The progress bar started
6. Everything stopped before the progress bar reaches the end, and no mp3 file to be found
This has worked for me before, and problem just happened now. I am using Audacity 2.3.2, and Windows 10. Have tried reinstalling and the same problem persists. Any help very much appreciated!
Cannot export.
Samuelalfaro
Re: Cannot export.
You can try standard Windows tools.
1. Restart the computer.
2. Update the OS using Mediacreationtool.
3. Full reinstall Windows.
Re: Cannot export.
What was the full and exact location and file name that you were trying to export?
