Recording 3 mics with Behringer UMC404HD
Faisal600
Post by Faisal600 » Sat Jul 06, 2019 3:11 pm
Hi everyone.
This is my first time using Audacity. So please be gentle on me
I'm trying to record 3 mics in the same time but I seem to be struggling to add the third one. I can only record two at a time.
Please help
Audio interface: behringer audio interface 4-channel umc404hd
Mic: Behringer Ultravoice XM1800S Handheld Supercardioid Dynamic Microphone (Set of 3)
OS: Windows 10
Reason: Give topic a meaningful title.
Trebor
Re: HELP please !
Post by Trebor » Sat Jul 06, 2019 7:00 pm
Try the Microsoft recording device option to see if that gives more than 2 channels ...
https: //manual.audacityteam.org/man/multi_channel_recording.html
As a plan-B consider Audacity's competitor OCENaudio,
Its less powerful as an audio editor than Audacity, but more compatible with multi-track recording,
(via ASIO compatibility).
You could record in OCENaudio, then edit the recording in Audacity, (both are free).
Faisal600
Re: HELP please !
Post by Faisal600 » Tue Jul 16, 2019 6:24 am
I've tried that to no avail.
Re: Recording 3 mics with Behringer UMC404HD
Post by steve » Tue Jul 16, 2019 8:18 am
Is there an option to set the number of channels to 3 in the device toolbar?
Note that for recording 3 channels on a 4 channel interface, you should use input channels 1, 2 and 3.
Faisal600
Post by Faisal600 » Tue Jul 16, 2019 4:39 pm
Hi Steve,
that's exactly what I want to achieve. I want to have three channels but I can't seem to know how :(
I can only record audio from Mic 1 and 2 simultaneously . However, Mic 3 I have to toggle the Recording device into Mic 3-4
Please see attachment
Image-1 (1).jpg (203.78 KiB) Viewed 2166 times
Post by steve » Tue Jul 16, 2019 4:55 pm
Try the other two "host" options in the device toolbar (Direct Sound and WASAPI) and see if either of those offer more than 2 channels.
DVDdoug
Forum Crew
Post by DVDdoug » Tue Jul 16, 2019 4:59 pm
From what I read here on the forum, very few people are successfully multitack recording with Audacity. :(
The Behringer website says your interface should have come with Tracktion. It also says:
Compatible with popular recording software including Avid Pro Tools*, Ableton Live*, Steinberg Cubase*, etc.
You could also try CakeWalk which is now FREE.
Faisal600
Post by Faisal600 » Wed Jul 17, 2019 5:53 am
Hi Steve,
and thanks for replying so fast. Nope there's only two channels with WASAPI or Windows DirecctSound
Faisal600
Post by Faisal600 » Wed Jul 17, 2019 6:03 am
DVDdoug I'm not entirely sure. See, I've inherited this setup from a friend of mine (before leaving country) and he was successfully recording all three mics with ease. Needless to say his computer was Macbook and mine is Lenovo. So maybe it's a hardware thing ?
Post by steve » Wed Jul 17, 2019 7:27 am
Look in the Windows Sounds Control Panel, and in the recording tab, open the "Properties" for the UMC404HD.
Can you set the device properties to "4 channels"?
