Hi,
I have Windows 10 and Audacity 2.3.2.
I added a "Click" Track by going to Generate > Rhythm Track, selecting my preferences like Tempo (bpm) and Beats per bar, and clicking Ok.
My question is...how do I get back to that screen and edit those options if I wish to change them after I have already added the Rhythm track?
Thanks,
Jeff
How to edit a Rhythm Track?
Re: How to edit a Rhythm Track?
Select the audio that you want to replace (the rhythm track), and apply the "Rhythm Track" generator again with your new settings. The newly generated rhythm track will overwrite the selected audio.
If you're not sure how to "select the audio", see: https://manual.audacityteam.org/man/aud ... ction.html
Thank You!
