Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Thu Jul 04, 2019 12:57 pm
wuhan_87 wrote: ↑Thu Jul 04, 2019 12:55 am
I reduced the gain on my audio interface as I think my previous signal was way too hot. I have minor sibilance now so I don't know whether to de-ess?
sibilance.wav (1.68 MiB)
If you want commercial-quality smoothness you'll need
Paul-L's precision de-esser & de-clicker plugins,
(or commercial equivalents).
- Paul-L's precision plugins.png (36.96 KiB) Viewed 176 times
wuhan_87
Post
by wuhan_87 » Thu Jul 04, 2019 6:56 pm
Ok, thanks.
What kind of scale are you using for the spectrogram?
How did you work out the values to plug in for de-esser? My spectrogram doesn't show values for more than 14000hz even if I change the max in the dialogue box for this.
Cheers
Trebor
Post
by Trebor » Fri Jul 05, 2019 1:01 am
wuhan_87 wrote: ↑Thu Jul 04, 2019 6:56 pm
Logarithmic ...
- spectrogram_settings.png (23.93 KiB) Viewed 151 times
From the spectrogram.
My spetrogram doesn't show values for more than 14000hz even if I change the max in the dialogue box for this.
There is an option to zoom in/out on the spectrogram ...
place the cursor on the spectrogram frequency scale, hold down the "ctrl" key, & use the mouse scroll-wheel ...
- zoom in-out using ''ctrl''+ scroll wheel.gif (1.68 MiB) Viewed 143 times
