cannot save project or export it...
Rosaberge2
Post by Rosaberge2 » Thu Jun 20, 2019 12:53 pm
hello people,
I'm new in those types of forum, but I really need help and hope that you can help me.
I started to enregitre my voice inside audacity, I come to save it and it' say that the files doesn't exist!
In my head it's normal that the files doesn't existe I try to create it!
I don't know if i do something wrong but I really need the wav files for my projects.
I hope that you can help me.
Rosaberge2
Re: cannot save project or export it...
Post by kozikowski » Thu Jun 20, 2019 8:05 pm
You can get errors like that if you try to use punctuation marks in your filename other than -dash- and _underscore_. Today is not 6/20/19. It's 2019-06-20. No slashmarks.
Rosaberge2
Post by Rosaberge2 » Fri Jun 21, 2019 12:29 am
well I don't use points in my names files… I still get the error…
do I need to not put space bar in the tittle?
by exemple:
1 2 3
1_2_3?
but thank you for sharing.
Rosaberge2
Post by steve » Fri Jun 21, 2019 9:38 am
What is the full and exact message (without missing anything out or changing anything)?
Which exact version of Audacity are you using?
Which operating system are you using?
Rosaberge2
Post by Rosaberge2 » Fri Jun 21, 2019 11:17 am
my version of audacity is 2.3.2 and I use it on windows 10.
the message say that I cannot save my files because the files doesn't exist. when I try to export it, the same message is wroten.
it cannot find the files name, check the file name and try again.
I hope this can help.
Post by steve » Fri Jun 21, 2019 11:39 am
Please quote exactly and in full what the message says. Without the full and exact message, it could be anything causing the problem.
Rosaberge2
Post by Rosaberge2 » Fri Jun 21, 2019 11:41 am
well this is the message it cannot save because the file name doesn't exist, check the files name and try again.
this is the only message I got when I try to save or export.
Post by steve » Fri Jun 21, 2019 11:49 am
OK, let's try another way: Please post a screenshot of the message.
Rosaberge2
Post by Rosaberge2 » Fri Jun 21, 2019 12:00 pm
I hope you understand french :?
I forgot to put it in English...
Post by steve » Fri Jun 21, 2019 12:21 pm
In the search box of the Windows Start menu, type: cmd
and select the "Command Prompt" app.
When the Command Prompt window opens, you should see a prompt:
Code: Select all
C:\Users\Utilisateur>
Do you see that?
If you do, then type:
Code: Select all
dir "C:\Users\Utilisateur\Desktop\son"
That will print a list of all files and folders in that location.
Post a screenshot of this.
Question:
What exactly did you press / click to get this message to appear? (please be precise).
