Harsh 'T' sounds... and S too I think
londonvictoria
Hi
I've uploaded a recording I have made that I would appreciate some help with
http://www.victoriawardhypnotherapy.com ... iz56kb.mp3
Forward into the middle of it and you'll notice all the Ts sound really harsh, especially on headphones (how this should be listened to).
Is there a solution that someone who isn't that clued up with Audacity could follow?
The Ss are a problem too I think.
This is quite a low quality 56kbps export. I think it's worse on the 320 one I have done.
I'm hoping this is quite a simple solution for the folk on here who are pros at this!
Many thanks
Victoria
Many thanks
Victoria
Re: Harsh 'T' sounds... and S too I think
The presentation has "ice pick in the ears" sibilance and "essing." I can well imagine what listening to that on headphones would be like.
You also have compression (talking into a milk jug or wine glass) distortion.
Record your voice and export a safety copy as WAV (Microsoft) 16-bit. Mono WAV quality is somewhere up in the 700s, and it doesn't change. Do all the editing in Audacity Projects or WAV and then, way at the end when you're getting ready to ship the final product, then make the MP3. So that should solve the honky sound. That, not coincidentally, is the recommendation for audiobooks.
Sorry, once it does that, the track is trash There is no good way to take that kind of damage out.
Are you using a home USB microphone such as the Blue Yeti? Those are famous for overly crisp, sharp, gritty, piercing sound. I think the makers assume that sounds "professional." It makes my ears bleed.
There is a DeEsser which can help.
viewtopic.php?p=245549#p245549
I have some notes on how to use it here, somewhere.
As we go.
Oddly, that's not it. You can produce a perfectly acceptable non-stereo presentation at 56 and nobody will notice. The mono limit is somewhere in the 30s. However, you can't produce your voice track in MP3. Every time you edit or do corrections or production in MP3, the sound quality goes down and you can't stop it. If you do enough careful editing and cleaning, the voice will start to sound like bad cellphone.This is quite a low quality 56kbps export.
As we go.
Found it.
viewtopic.php?p=366074#p366074
The DeEsser defaults are not the best and that's the set I use.
One shortcoming of the DeEsser is the need to produce the voice track first, before you apply the tool. That's what the audiobook mastering suite is doing. That's not a bad way to stabilize your track volume for your products, although it does less well with music. Do the voice corrections first, then add music.
I promise to only drive on the freeway after my seizure.
londonvictoria
Hi. Thanks for this.
I have the file that I made in audacity, so I have the original project files. Can you help me with that, if I go back to the editing stage.
I only exported and put it up as an MP3 for people to listen to to give me advice.
But I still have the whole lot in all the separate tracks (two voice tracks and a music track, all in stereo)
Thanks so much for taking the time to write your answer.
(And I'm using a yeti... blue snowball??? mic)
londonvictoria
ha.kozikowski wrote: ↑Thu Jun 20, 2019 11:15 amI promise to only drive on the freeway after my seizure.
That Audacity de-esser plugin, (By Paul-L), does not have a "linked stereo" option:
it will add a weird spatial [sic] effect if applied to voice which has had stereo reverb added.
You should apply that de-esser to mono vocal before any reverb (or music) has been applied.
There is a simpler faster but less-precise de-esser plugin here, (by Steve).
It always has "linked stereo" which avoids the unintentional spatial effect.
londonvictoria
Thank you for your reply. I'm not entirely sure what 'linked stereo' is. Is it "joint stereo"?
What I have is four stereo tracks. One has my voice. One has music. And the other two are my voice but one just in the right and one just in the left.
When I exported it to MP3 before, I used "stereo" not "joint stereo" because I had read that was better when you want something to clearly be in one ear or the other (like my last two voice tracks).
SO
At the moment, open in my audacity programme, are those 4 tracks.
What I'm not sure that I understand, is the exact process I should go through. You say it should be applied to a mono voice... do you mean to split my main vocal stereo track into mono and desser it... or can I de-esser it while its still stereo.
Do I need to delete the music and secondary voice tracks and then de-esser it, because it's going to apply it to the WHOLE 4 tracks at once, and I only want it on the main vocal... or can I just select the main track and de-esser it.
I'm sorry. I had no idea this would be this tricky. I sailed through putting it together, was happy with it, then listened to it on headphones and EEEEEEEEEEK!
SO
londonvictoria
Hmmm, i'm feeling a bit overwhelmed with this!
I'm trying to install the de-esser. I can't even figure that out. I've followed a link in this forum to a page in a wiki that says to install it using Tools>nyquist plugin installer...
But I don't have that under Tools. (Only "nyquist prompt" - which I don't know how to use - I tried opening the desser.ny file in that and it loaded up what looked like a text file, that when I 'ran' it, just came back with a dialogue box saying De-essed Nyquist returned the value 10, but didn't seem to actually do anything.... What is that???)
Is there an idiots guide somewhere??
londonvictoria
Right.
I was on an old version of audacity. I now have the de-esser installed.
BUT... it's not making much difference :/
I am running it on ONLY the main vocal track, which is a stereo track.
Is that right?
Is that right?
