Curser too small
SteveB7
Curser too small
Post by SteveB7 » Mon Jun 03, 2019 7:20 am
Hi everyone,
I am having trouble seeing the curser on the track pane, It is extremely small and I can't find a way to enlarge it.
Does anyone know why this is happening and how to fix it?
Trebor
Re: Curser too small
Post by Trebor » Mon Jun 03, 2019 9:31 am
Selecting a different color scheme/theme may help ... https://manual.audacityteam.org/man/themes.html
SteveB7
Post by SteveB7 » Mon Jun 03, 2019 10:18 am
Thank you Trebor,
Unfortunately that didn't change the size of the Curser on the trackpane, thank you for your reply.
Post by kozikowski » Mon Jun 03, 2019 6:01 pm
My Audacity follows the size of my computer cursor. Google.
Screen Shot 2019-06-03 at 11.00.08.png (82.57 KiB) Viewed 863 times
SteveB7
Post by SteveB7 » Tue Jun 04, 2019 10:11 am
Hi Kozikowski,
Thank you for your reply but unfortunately no change to the curser size on the Track Pane.. It did change the size of the Pointer off the Track Pane, but when I move the pointer back to the Track Pane the curser reduces to a very small line again and is very hard to see.
Regards Steve
Post by steve » Tue Jun 04, 2019 12:31 pm
Audacity is built with WxWidgets, which is a cross-platform toolkit for making graphical applications that work on multiple platforms (Audacity supports Windows, macOS and Linux).
In WxWidgets, custom cursors are created as 32x32 bitmaps, and as far as I'm aware, there is not yet any way to scale this size within the application. Until WxWidgets provides a way to create custom cursors that can be scaled according to the display dpi, I think your options are:
  • Reduce the display dpi for your monitor.
  • See if Windows provides "display scaling options" in Settings that allow you to improve the appearance (I don't use Windows, so you'll need to test this yourself).
  • Use a third party app to "magnify" Audacity (there may be some "accessibility" app that can do this).
  • Add a second display to your computer with a lower dpi (dots per inch).
  • Put up with it.
Final thought:
There's an option in "Mouse Properties > Pointer Options" to "Show location of pointer when I press the CTRL key". I don't know if that works when using one of Audacity's custom cursors, but perhaps worth a try.
SteveB7
Post by SteveB7 » Wed Jun 05, 2019 8:09 am
Hi Steve,
Thank you for your advice, I will give them a try and see how they go.
Regards
HjAa
Post by HjAa » Sat Aug 22, 2020 7:59 am
I'll suggest changing the theme to "Dark" - it makes the cursor stand out a lot more! :)
GRD
Post by GRD » Tue Feb 16, 2021 4:24 am
There does not seem to be an easy work around to this problem for high resolution screens running Windows 10. I tried to toggle between "System", "System Enhanced" and "Appliction" in High DPI Scaling Override, to no effect. Technically this should have worked. (To do this Right click on Audacity icon, click on Properties, then select Compatability, click on Change DPI Setting tab, Select "High DPI Setting Overide" and then choose one of the three options mentioned above, click OK, then click Apply in the other window).
The one work around I found was to go to Windows 10 Display Settings and changing the resolution to 1920 X 1080. This did not shrink the displayable screen and put the Selection and Zoom Tool cursors i Audacity to a normal workable size. Once I am done with editing in Audacity, to change the diplay back to its normal resolution. This works, although it is not an ideal fix.
-Geetha
