How to record 2 tracks from separate sources into 2 tracks?
demolitiondan
Post by demolitiondan » Wed May 29, 2019 7:18 pm
Hi,
I'm a new member to the forum but have been using Audacity for a long time.
I'm using version 2.0.5 and Windows 10.
I have a weekly (pre-recorded) radio show and want to record the music track and microphone track separately so I can tidy the mic track before broadcast.
Currently I can only record from a single source - even if I open 2 separate Audacity windows.
Could this be fixed with a more advanced soundcard or is it a limitation of audacity?
TIA
Dan
Re: How to record 2 tracks from separate sources into 2 tracks?
Post by kozikowski » Wed May 29, 2019 7:27 pm
Those are fuzzy words. You are producing a radio show and submitting it for broadcast?
Are you playing the music live or using MP3 or other prepared music?
Is the music tightly bound to the voice or is it just intro, outro, stingers?
There was a forum poster who produced a music radio show from downloaded MP3s and live introduction at home, and then submitted it for broadcast later. Is that what you're doing? Desert Island Disks?
demolitiondan
Post by demolitiondan » Wed May 29, 2019 7:41 pm
Hi, it's an internet radio show.
The current format is I submit a radio show fully produced to the station.
Example:
https://www.mixcloud.com/demolitiondanh ... sco-house/
It's one hour of beat matched house music recorded from a Pioneer DDj setup.
I do an hour of talkover which is synchronised to the quiet sections (drops).
It's a professional station (Sister Bliss, Roger Sanchez, Graeme Park, Cevin Fisher are my contemporaries) so it's got to sound as good as I can make it.
If I mess up the talkover and it's all one track I have the risk of having to re-record the whole show over again so recording 2 separate tracks is essential. I started by recording the music and then recording the voiceover as a separate track. That's 2 hours for a 1 hour show and after post-processing can be 3 - 4 hours.
I want the Audio from my Pioneer into one Audacity channel and the voiceover into a second one, can it be done?
TIA
Dan
demolitiondan
Post by demolitiondan » Wed May 29, 2019 7:43 pm
Example:
TIA
Dan
Post by steve » Thu May 30, 2019 8:38 am
That's an ancient version of Audacity. You should update to the current 2.3.2 version: https://www.audacityteam.org/download/windows/
Record (or better to "Import" if possible) the music track first. Then record the microphone to a new track.
In Audacity 2.3.2, use "Shift + R" or "Shift + Record button" to record to a new track.
Yes, that can be done. Do you want your music to be mono or stereo?
Do you need to retain an archive copy that retains the separation of music and voice?
demolitiondan
Post by demolitiondan » Thu May 30, 2019 1:31 pm
Hi,
I've tried recording the music (stereo) and then doing the voice over (mono) separately but by the time I'm done it takes me 3 hours to record a one hour show.
What I really want to do is record both simultaneously to separate tracks and maintain the ability to edit separately - mainly to remove pops and amplify quiet bits on the voiceover track.
I can record onto separate devices (I recorded the music onto the laptop running Pioneer RekordBox this week but it dropped a load of the recording - the voiceover I recorded onto Audacity). This week has taken even longer!
I don't mind buying a new sound card if I need one but I'm pretty sure I have a SoundBlaster in a drawer which I could install as a second sound card in my PC.
Thanks
Dan
Post by steve » Thu May 30, 2019 1:48 pm
Audacity only supports recording from one audio device at a time. If you need to record more than 2 channels, you need an audio device that supports more than 2 channels, AND, supports more than 2 channels with standard Windows drivers (Audacity cannot ship with ASIO support due to licensing restrictions.)
Unfortunately, on Windows, many multi-channel audio devices appear to Audacity as 2 or more stereo devices. This is bad because Audacity can only record from one at a time. Multi-channel support is generally better on macOS, Linux, or Windows with ASIO drivers (but as said already, Audacity does not ship with ASIO support).
Post by kozikowski » Thu May 30, 2019 3:55 pm
You're doing well. The rule for an edited show is 5X.
Right. You are talking yourself into two different recorders. You produce the music track on one machine and your voice on the other—all in real time. Export the voice track and import it into your mix. Obviously, they're separate tracks and you can do corrections and sweetening as you wish.
Screen Shot 2019-05-30 at 08.50.35.png (199.65 KiB) Viewed 182 times
That's my Zoom H4 recorder in a kitchen table studio. The paper towels are Piggly Wiggly. YMMV.
You will almost certainly have a start-stop timing problem the first time, but Effect > Change Speed and Time Shift Tool until you get everything to match. You will only have to experiment once to get the correction value. It will be the same value forever as long as you don't change recorders.
Post by kozikowski » Thu May 30, 2019 3:56 pm
If you get another method to work, post back.
Post by kozikowski » Thu May 30, 2019 4:36 pm
There are other methods, but probably not a button-push from where you are now.
Do you have a smartphone? They all have voice recorders.
You can probably get your computer to do everything, but maybe not with Audacity.
There is a list of multi-channel devices.
viewtopic.php?f=27&t=38626
There was a software package that allowed multi-channel in Audacity, but it smashed everything into one show. Not what you wanted.
