Missing Windows Lame File
marilynd
Post by marilynd » Wed May 29, 2019 1:48 pm
I've been using Audacity with no problems for about 10 years. Just installed it on my new Windows 10 PC and can't export mp3 files, it keeps asking for a lame extension however when I follow the download link it takes me to a page which reads as per the text below and therefore doesn't offer a download and installation option:
LAME is now built-in as part of Audacity
The software patent on LAME encoding library has expired, so now the LAME library for MP3 export is built-in with Audacity for Windows.
Any tips or ideas gratefully received.
Re: Missing Windows Lame File
Post by kozikowski » Wed May 29, 2019 2:01 pm
It only does that in Audacity 2.3.2. Earlier Audacity versions had to be patched.
https://www.audacityteam.org/download/windows/
Audacity 2.3.2 is a major change from earlier versions. It's a 64-bit app now, so computers will stop complaining about that and, as above, it has the MP3 software built-in.
waxcylinder
Post by waxcylinder » Wed May 29, 2019 5:58 pm
Audacity is only 64-bit on Mac (and some Linux IIRC) - but definitely still 32-bit on Windows.
Peter.
Post by kozikowski » Wed May 29, 2019 6:32 pm
But all those versions have Lame built-in?
marilynd
Post by marilynd » Wed May 29, 2019 8:47 pm
Great. Thank you for the link I'll try uninstalling and re-installing. Fingers crossed!
waxcylinder
Post by waxcylinder » Wed May 29, 2019 9:49 pm
Yes indeedy they do, from 2.3.2 onwards.
Peter
