First track recorded fine, others not [SOLVED]
yannik131
Post by yannik131 » Sun May 26, 2019 5:34 pm
Hello,
I'm recording the signal of my POD500X with Audacity 2.3.2 on Windows. These are the recording options that I can choose from and the errors I'm getting:
MME -> Digital Audio Interface (Line6 POD500X):
First track is recorded perfectly fine. If I add a second (or third or more) track, after recording I get the message
Recorded audio was lost at the labeled locations. Possible causes:
Other applications are competing with Audacity for processor time
You are saving directly to a slow external storage device
The second track is off-pitch, has low sound quality and has distinct cut-noises every second (which are marked by Audacity).
Windows DirectSound -> Digital Audio Interface (Line6 POD500X): Same problem, just no error message
Windows WASAPI -> Digital Audio Interface (Line6 POD500X): First track fine, after adding a second one when pressing record I get "Error code -9997: Invalid sample rate".
Sample rate of all tracks is 44.1 kHz (as is the output of my POD). I have a fast SSD with ample space left, tried closing every other application and even turning off WiFi. Any ideas what's going on?
Re: First track recorded fine, others not
Post by steve » Tue May 28, 2019 12:51 pm
Check in the Windows Sounds settings and ensure that both the playback and recording devices are set to a sample rate of 44100.
yannik131
Re: First track recorded fine, others not [SOLVED]
Post by yannik131 » Tue May 28, 2019 9:09 pm
That was indeed the problem! Thanks a bunch! :)
