Effect from Amplitube 4 to Audacity
Hi is possible to add effects from amplitube 4 to audacity? when i try to do so i see a message saying "could not find the library" there is a solution? thank you
Re: Effect from Amplitube 4 to Audacity
Audacity on Windows is currently only available as a 32-bit application and so can only run 32-bit plug-ins. Amplitude 4 is only available as a 64-bit application so it won't work in Audacity. However, Amplitude 4 can also be run as a stand-alone application.
When run as a stand-alone application, it "may" be possible to record from it with Audacity by following the procedure for "Recording audio playing on the computer": https://manual.audacityteam.org/man/tut ... puter.html
(I've not tested as I don't have Amplitude).
