How do I get rid of this.........see attached. I simply want to start from zero
Thanks
Bob H
Audacity 2.3.0
Starting from 0
Re: Starting from 0
If you look over to the left side of the display, you will see a red thumb-pin. If you click on it to unpin it (it turns green), then the track display should begin at zero.
Re: Starting from 0
Thank you....always a pleasure dealing with you folks, I get fast and accurate answers to my, mostly inane, questions.
Bob H
Bob H
Re: Starting from 0
It's a pleasure dealing with a poster furnishing a clear question with illustration.
