View - History
View - History
The history has ceased to be reflected. Something is wrong. Please help fix it!
Re: View - History
Only this. And all other operations doesn't reflect.
- Attachments
- Untitled.png (39.14 KiB) Viewed 306 times
Re: View - History
It looks like you imported a file.
Re: View - History
Thank you! The problem was solved by simply restarting the computer. What it was - I do not know, maybe a lack of memory.
Re: View - History
Should file export be reflected in history too? I have not export in history.
Re: View - History
From the manual: "History lists all undoable actions performed in the current project, including importing."
https://manual.audacityteam.org/man/vie ... ml#history
Technically: The History window shows the record of "project state" changes. When a change of state is pushed to the Undo stack, it is logged in the History window.
Export cannot be undone (not "undoable") and does not change the state of the project.
Re: View - History
Thank you!
