Noise reduction effect.
юра00
Post by юра00 » Wed May 01, 2019 6:50 am
Dear specialists! Is it possible to make, when the noise model has already been created, but the effect has not yet been applied, is postponed, so that there is some sort of mark, a signal that the noise model has been created, but not applied? And then, you often create a model, you don’t apply it right away - and then you simply forget that you need to apply it. You export the file and you don't remember whether you have deleted the noise or not.
Re: Noise reduction effect.
Post by kozikowski » Wed May 01, 2019 10:15 am
I believe the Noise Profile hangs around until you close Audacity. It doesn't hang around until you change it which is how many of the other effects work.
Post by kozikowski » Wed May 01, 2019 10:16 am
One more. I don't think there is any way to save a profile, other than saving the portion of sound used to make the profile.
юра00
Post by юра00 » Wed May 01, 2019 11:41 am
First you need to enter the noise model. I select the area, open the effect - and click, as in the drawing.
юра00
Post by юра00 » Wed May 01, 2019 11:45 am
Now you need step2. But while I am postponing it, I perform some other actions. And after these actions it is necessary to apply the effect itself.
юра00
Post by юра00 » Wed May 01, 2019 11:48 am
But the fact of the matter is that while I performed these actions, I often just forget about the noise, export the file - and the effect remains unapplied. The meaning of the question is that during this period, while the noise model has already been created, but other actions are being performed, there was some kind of clue on the screen that the effect has not yet been applied so as not to forget.
Post by steve » Wed May 01, 2019 11:50 am
Surely there's an audible clue when you listen to the track before you export.
юра00
Post by юра00 » Wed May 01, 2019 1:31 pm
Will not work. With the selected parameters close to the minimum values, "by ear" it is impossible to say whether there is an effect or not. That is, only a slight change. I keep in mind visual clue.
Post by kozikowski » Wed May 01, 2019 2:33 pm
There is no visual clue.
юра00
Post by юра00 » Wed May 01, 2019 3:17 pm
This is practically the only effect that is in 2 stages. The rest in one, in my opinion. Because of this, there was a topic.
