Audacity 2.2.2 Windows 10
editing a siminar when cursor turns into a magnifying glass wherein waveform can be expanded or deminished all thats nice and dandy but its not what i'm doing and I can't get out of it. this happened 2 nights in a row. when this happened playback of the aup was over with - editing was overwith -the onlything that I could do was explode or shrink waveform - escape would not resolve it. the first time it crashed and I lost the file I was working on second time I was able to save the file I was working on but had to ditch all my hard work I had put into it. so far it has done this only after I have been working on the files for 45 to 50 minutes into the speech wherein a lot of editing had taken place removing pause between speech and correcting stuttering coughs "uhhs" etc. help
jellyfishjuice
Re: editing a siminar when cursor turns into a magnifying glass
You may have accidentally pressed the F4 key, or clicked on the zoom tool button. Press the F1 key to get back to the normal cursor.jellyfishjuice wrote: ↑Tue Apr 16, 2019 11:48 pmcursor turns into a magnifying glass wherein waveform can be expanded or deminished
(See: https://manual.audacityteam.org/man/zoom_tool.html)
