Installation Problem
koehd896
Operating System: Windows 7
Post by koehd896 » Fri Apr 05, 2019 12:11 pm
I am trying to install audacity and get the following error message when I try to run it:
"The Program can't start because api-ms-win-crt-runtime-I1-1-0.dll is missing from your computer. Try reinstalling the program to fix this problem."
I have no problem downloading the files, I have tried the windows installer and zip files, the most current version (2.3.1) and an old version (2.3.0) and I still get the same error message. Any suggestions? I am using a school laptop, could it be some sort of restriction on the computer?
Re: Installation Problem
Post by steve » Fri Apr 05, 2019 12:18 pm
The problem is that the computer is missing some Windows updates.
Audacity requires "Visual C++ Redistributable for Visual Studio 2015 ", which is available from Microsoft here: https://www.microsoft.com/en-ie/downloa ... x?id=48145
KerimF
Post by KerimF » Fri Apr 05, 2019 4:50 pm
I run Audacity 2.3.0 on Windows 7 (installed on a folder from the downloaded zip file).
Doesn't this mean that "Visual C++ Redistributable for Visual Studio 2015 " is already installed on my computer?
Would you please tell me if it doesn't.
Thank you.
Post by steve » Fri Apr 05, 2019 5:03 pm
You have probably got an older version (too old).
KerimF
Post by KerimF » Fri Apr 05, 2019 5:09 pm
Just to be sure I got what you meant, I will have to download "Visual C++ Redistributable for Visual Studio 2015 " to install and run 2.3.1.
Post by steve » Fri Apr 05, 2019 5:28 pm
Yes.
