Ringing sound when playing
randomperson
Operating System: Windows 7
Re: Ringing sound when playing
Post by randomperson » Tue Mar 26, 2019 2:18 am
Never mind, I found the solution afterwards. I had to go to Edit/Preferences, Devices, Interface, and change Hosts from MME to either Windows DirectSound or Windows WASAPI.
Post by kozikowski » Wed Mar 27, 2019 1:41 am
Glad you were able to sort it.
