Is there any way to jump to the next/previous label? [SOLVED]
Emerogork
Post by Emerogork » Tue Mar 12, 2019 10:32 pm
I have a 24 hour recording and marked points of interest as it was recording. It would be move to get to the points without having to skate through the recording looking for them.
Re: Is there any way to jump to the next/previous label?
Post by steve » Tue Mar 12, 2019 11:33 pm
Click in the label track, then use the Tab key.
Emerogork
Re: Is there any way to jump to the next/previous label? [SOLVED]
Post by Emerogork » Wed Mar 13, 2019 2:09 am
I could have sworn that I had tried that.
it works
Thanks
