mute/unmute selected tracks
jaja714
Post by jaja714 » Mon Feb 25, 2019 2:08 pm
Is there any way to mute/unmute selected tracks?
waxcylinder
Re: mute/unmute selected tracks
Post by waxcylinder » Mon Feb 25, 2019 3:14 pm
Not based on track selection
But yes, use the Mute button on the track's Track Control Panel - see: https://manual.audacityteam.org/man/aud ... html#panel
You could temporarily "mute" selected tracks by turning them to silence with Ctrl+L - and then restore them with Undo - but you wouldn't want to do anything else in-between as Undo is not selective, it woks backward through each command one at a time.
