Windows 10, Audacity Portable 2.2.2.
Please see screenshot attached: upper half of the track has disappeared.
Did I accidentally hit a button or something? Not sure how to restore it...
Thanks for any bright ideas..!
Upper half of track missing
- Attachments
- screenshot of upper half of track missing
- upper half of track missing.PNG (17.14 KiB) Viewed 277 times
Re: Upper half of track missing
Post another shot this time with the left scale (volume) visible.
waxcylinder
Somehow you have made a vertical zoom
Right-click in the vertical Scale ( the vertical bar between the waveform and the Track Control Panel) and select Zoom Reset
See this page in the Audacity Manual: https://manual.audacityteam.org/man/ver ... oming.html
waxcylinder
waxcylinder
waxcylinder
