RoVee plug added but not usable
oranges
Post by oranges » Thu Feb 21, 2019 6:22 am
Hi, this is on Audacity Portable which I've been using on various computers (and various versions of Windows).
I extracted the RoVee voice changer plugin and put it in my plugins folder, then added it through Effects>Add/remove effects> (selected it) > enable. But depending on which computer I used this program on, it either does not show up in the effects list at all (though says it's enabled in the add/remove list) or it is in the effects list, does open, but does not operate properly:
You can input different setting numbers but it defaults to the same preset sound.
Thanks in advance for any bright ideas...
Re: RoVee plug added but not usable
Post by steve » Thu Feb 21, 2019 9:00 am
Which version of Windows?
Which version of Audacity? (look in "Help > About Audacity")
Which version of RoVee?
Have you tested with a fully installed version of Audacity 2.3.0?
oranges
Post by oranges » Fri Feb 22, 2019 1:40 am
Windows 10, Audacity Portable 2.3.0, RoVee 1.10
I am not able to fully install on any computer at the moment as I don't have my own computer (hence portable apps)
Post by steve » Fri Feb 22, 2019 8:16 am
hence portable apps
Perhaps worth asking on their support channel: https://portableapps.com/support
