Does Audacity work with iZotope Ozone?
Prizm
Post by Prizm » Sun Feb 10, 2019 4:23 am
I couldn’t find a straight answer for this. Can anyone confirm that iZotope Ozone works correctly with Audacity on Windows 10?
I didn’t want to buy the plugin only to find it doesn’t work properly.
Thanks
waxcylinder
Re: Does Audacity work with iZotope Ozone?
Post by waxcylinder » Sun Feb 10, 2019 1:32 pm
This iZotope page shows the supported hosts: https://www.izotope.com/en/products/mas ... specs.html
I don't see Audacity listed there - nor have I tried downloading and using Ozone.
Post by steve » Sun Feb 10, 2019 1:57 pm
According to feedback on this forum, most iZotope do not work with Audacity.
Host applications that are supported by iZotope are listed on their website. For Ozone 8, that's here: https://www.izotope.com/en/products/mas ... specs.html
waxcylinder
Post by waxcylinder » Sun Feb 10, 2019 2:30 pm
Some do though - I have iZotope Vinyl running sweetly on my W10 laptop as a plug-in in Audacity - it's a great plug-in eanbling you to restore all that fabled vinyl "warmth" ;)
Peter
DVDdoug
Forum Crew
Post by DVDdoug » Sun Feb 10, 2019 4:12 pm
It also runs as a stand-alone application. And there is a 10-day free trial.
Trebor
Post by Trebor » Sun Feb 10, 2019 8:14 pm
The free ozone imager plugin works in Audacity ...
Prizm
Post by Prizm » Fri Feb 15, 2019 12:59 pm
Thanks everyone.
Oxenhandler
Post by Oxenhandler » Thu Feb 21, 2019 6:21 pm
Peter, do I need a plug-in host to enable izotope vinyl? or more specifically, now that i've downloaded it, how do I open it and run it? If I need a plug-in host, I'll have to download one, can you recommend a good (free) one? Thanks.
Trebor
Post by Trebor » Thu Feb 21, 2019 8:35 pm
... do I need a plug-in host to enable izotope vinyl?
or more specifically, now that i've downloaded it, how do I open it and run it? ...
I can testify izotope vinyl will run in Audacity on Windows ...
izotope vinyl in Audacity on Windows.png (158.25 KiB) Viewed 3827 times
https : //manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html#vst_install
waxcylinder
Post by waxcylinder » Fri Feb 22, 2019 12:07 am
Basically you shoiuld just bneed to go to ythe Plug-in Mananger in Audacity (use "Add/Remove Plug-ins" the top menu item in the Effect menu). lokk at the "New" items, and enable iZotype Vinyl - and don't forhet then to click the OK in the dialog.
See: https://manual.audacityteam.org/man/man ... yzers.html
Like Trebor have iZotype Vinyl installed on my PC (downloaded using the installer on the iZotop site) and activated on Aufa=dacity as above - and it runs fine.
Peter.
