Change recording from 176.4kHz to 44.1kHz
TMillerLP
Operating System: Windows 7
Post by TMillerLP » Sun Jan 27, 2019 10:24 pm
using 2.2.2 and windows 7
I want to use faster rates (ex. 176.4kHz) and be able downgrade to 44.1k to create CD without re-recording everything. I've searched but haven't found this capability. I doubt I'm first to think of this. Seems like it might be a popular idea, so I've probably missed something.
Thanks in advance
TMillerLP
Re: Change recording from 176.4kHz to 44.1kHz
Post by steve » Mon Jan 28, 2019 12:32 am
Set the "Project Rate" (bottom left corner of the main Audacity window) to 44100 before you export. The exported file will take its sample rate from the Project Rate.
