How to set default "playback speed" slider
boonman
Post by boonman » Mon Jan 21, 2019 11:49 pm
When i startup Audacity, i'd like this slider to be at 2.25
https://i.imgur.com/SXL7eEk.gif
How do i set the default here? Someplace in cfg file?
Thanks!
Re: How to set default "playback speed" slider
Post by steve » Tue Jan 22, 2019 10:14 am
Double click on the slider, then type the number 1 in the text entry box and click "OK". Audacity remembers the last used setting.
Note that the playback speed setting only has an affect when clicking the "Play at Speed" button, and has no affect on normal playback.
boonman
Post by boonman » Wed Jan 23, 2019 3:23 am
That's true.
But it forgets every time i restart Audacity
So is there a way to set the default? e.g. in the cfg file?
Post by kozikowski » Wed Jan 23, 2019 4:11 am
Might you really want Effect > Change Speed, Effect > Change Tempo or Effect > Change Pitch?
Those are actual effects and can, I'm guessing, be programmed.
boonman
Post by boonman » Wed Jan 23, 2019 8:14 am
no i do audiobook mastering.
The audiobook might have 20 chapters, in 20 different AUP files.
When i playback an audiobook, i typically play at 2x speed (because they're so long)
So every time i open another AUP file, my Playback Speed bar is back down at 1x, and i have to carefully move it each time.
Post by steve » Wed Jan 23, 2019 10:04 am
I misunderstood your question. I thought you meant "how do I set it to the default", rather than "how do I change the default".
The default setting for Play at Speed is not configurable. However, you could add a keyboard shortcut to the "Adjust Playback Speed" command, which would then allow you to open the speed setting with one key press. See here for how to set a keyboard shortcut: https://manual.audacityteam.org/man/key ... ences.html
waxcylinder
Post by waxcylinder » Wed Jan 23, 2019 11:08 am
And if you do that you then just need to type 2 and the Enter - so just 3 keystrokes
But I will try to find some time to talk to the develoiper who recently worked on Play-at-Speed to make it dynamic to see if the Play-at-Speed setting could be "remembered" by Audacity or even also have a preferences setting (but we are wary of introducing additional preferences).
Post by steve » Wed Jan 23, 2019 11:14 am
I'd be a bit wary of that, unless there was also a very quick and easy way to reset it (right click context menu?).
I think that for most users, it's like driving a car - when you start the car, it should be in neutral. The effect can be quite unsettling if it's in third gear and you were unaware of that when you start the engine.
waxcylinder
Post by waxcylinder » Wed Jan 23, 2019 11:17 am
I don't really buy that argument Steve.
You could make the same case against stuff like the settings that are rembered for exports - and resetting those each time would be daft.
Peter.
Post by steve » Wed Jan 23, 2019 11:51 am
That's OK, we don't have to agree about everything :D but for my own use, I like the fact that Play at Speed always starts from a known (x1) position.
A few other "remembered" setting annoy me, such as how "Generate" effects remember durations that I have not set, just because I used the effect with a selection. (but this is going off-topic, so I'll stop now ;))
