- 4gS0Wrn.png (24.73 KiB) Viewed 79 times
Error message on recording
watermusiccooler
- Operating System: Windows 7
Reason: Insert image into post for direct viewing
Re: Error message on recording
Which version of Windows?
Which version of Audacity? (look in "Help > About Audacity")
What audio device are you trying to use?
What are your settings in the device toolbar?
