Sometimes when I make a new track and hit record with multiple tracks, it gives a really weird error about them not matching up and I have to close and relaunch to do anything.
Also, is it possible to collapse multiple tracks together?
Windows 7, Audacity Audacity 2.3.0, How do I merge audio tracks?
watermusiccooler
- Operating System: Windows 7
Reason: Insert image into post for direct viewing
Re: Windows 7, Audacity Audacity 2.3.0, How do I merge audio tracks?
Is this about the same problem as this: viewtopic.php?p=362407#p362407
You can mix multiple tracks together to make them into one track. See: "Mix and Render" on this page: https://manual.audacityteam.org/man/tra ... u_mix.htmlwatermusiccooler wrote: ↑Mon Jan 21, 2019 2:31 amAlso, is it possible to collapse multiple tracks together?
Once the tracks are mixed, you can't "explode" the mixed track back into the original multiple tracks.
watermusiccooler
watermusiccooler
I'll screenshot the error if it happens again, these are my settings though. https://i.imgur.com/fwDBxoP.png
It is a different error than the one you've linked me to.
