Applying Envelope Tool
Bojaniko
Operating System: Windows 7
Post by Bojaniko » Thu Jan 17, 2019 5:52 pm
Just as the title says, how to I apply the Envelope Tool to the audio I've used it on since trying to add any other effects removes the envelope
waxcylinder
Re: Applying Envelope Tool
Post by waxcylinder » Thu Jan 17, 2019 6:30 pm
See this page in the Audacity Manual: https://manual.audacityteam.org/man/envelope_tool.html
Bojaniko
Post by Bojaniko » Thu Jan 17, 2019 10:38 pm
Doesn't say how to apply it
waxcylinder
Post by waxcylinder » Fri Jan 18, 2019 2:31 pm
Yes it does - it says
"An amplitude envelope is manipulated by a number of control points. Each control point is visible by its four handles (the small circles in the image above), by which you can drag the point up or down to control the volume level. "
and goes on to say:
"Just click the mouse button anywhere in a track to create a new control point. "
"The entire track follows your new control point until you add another one. Click in a different spot to add a new control point. "
all with illustrative images
waxcylinder
Post by waxcylinder » Fri Jan 18, 2019 2:43 pm
I did though, just now, update the page slightly for the upcoming 2,3,1 manual to add a new section header for Control Points and tweaked/reordered the txt to try to make it clearer.
See: https://alphamanual.audacityteam.org/ma ... rol_Points
