audio sync with labels
Quantum
Post by Quantum » Mon Jan 07, 2019 4:51 am
I've had this issue from the beginning - and can't find any instructions how to fix it in the Manual. :roll:
whenever I set the labels (on the labels track) underneath an audio track I am editing eg with some editing notes or markers, and then edit the audio track in a way that it changes its length hence the position on the timeline - the labels do NOT move with the now repositioned audio points they are supposed to be associated with.
I have to move them manually to the relevant points on the timeline which are now in the new locations.
Clearly, I'm doing something wrong or missing a sync step, as I can't believe that the labels cannot be synced with the audio track (not the timeline itself).
I would be grateful for advice.
Re: audio sync with labels
Post by steve » Mon Jan 07, 2019 9:16 am
To "lock" the label track to an audio track, enable "Sync-Lock" https://manual.audacityteam.org/man/tra ... acks_onoff
Quantum
Post by Quantum » Tue Jan 08, 2019 9:33 am
thank you so much! !!!!!
how could I have missed it.....suffering for months in despair..... :(
Quantum
Post by Quantum » Tue Jan 08, 2019 9:56 am
I'm back.
I found a BIG problem.
Ths sync-lock is syncing not just the label track to the audio track right above it (which is what I was looking for) - but ALL TRACKS in the project!
as I work with multiple tracks and often have a label track underneath each of the voice tracks (up to 4), and continue editing my music track - I can't have ALL of them to be moving in sync as this creates chaos in my workflow - only one label track with one audio track right above it.
Can this be done?......
to rephrase my question - can I sync-lock a label track to ONE specific audio track?
waxcylinder
Post by waxcylinder » Tue Jan 08, 2019 10:04 am
Have a read of this page from the Manual: https://manual.audacityteam.org/man/syn ... roups.html
It explains (or at least I, as the editor of that page, hope it does) how to achieve multiple sync-locked groups each delimited by a label track - there is a picture on that page to aid understanding.
Post by steve » Tue Jan 08, 2019 1:43 pm
The short answer is : Yes, by adding another label track above the audio track, so as to form a "Sync-Lock Group" that has ONE audio track.
The full (longer) answer is to read the page that waxcylinder posted: https://manual.audacityteam.org/man/syn ... roups.html
Quantum
Post by Quantum » Thu Jan 10, 2019 5:55 am
aha....many thanks! 8-) :D
