It looks like Wavepad is going to do everything I need to do.
Wave Editor came in second but I would have had to download some extra software to to use a mic and record vocals. I think Wavosaur would have worked as well but the UI looked more complicated and outdated.
Nero Wave Editor would have worked but the download also loaded some extra computer performance testing software that I didn't want. It was easily uninstalled but I just don't like to deal with "sneaky" companies.
Mp3directcut would have worked but it just looked outdated.
I didn't try Mp3gain but it looked like it would have worked. WaveShop looked good but I don't think it is free so I didn't try it.
I couldn't confirm that Easy MP3 Cutter was non-destructive so I didn't try it. Simple MP3 joiner had bad reviews so I didn't try. Adobe Audition was not free - didn't try.
TuneKitten -couldn't get website to open.
I couldn't confirm that AudioJoiner is non-destructive so I didn't try.
Hope this maybe helps someone and thanks to all who replied. I appreciate your help. I learned a lot during this process.
Kind regards,
yeto
How do I connect 2 mp3 files back to back to make 1 song?
Re: How do I connect 2 mp3 files back to back to make 1 song?
Reason: format layout for easy readability
waxcylinder
Thanks for the useful feedback yeto
