Join labels together: Make end of one the start of the next
Blackadder
Operating System: Windows 7
Post by Blackadder » Sat Dec 22, 2018 3:50 pm
[Audacity v2.1.0; Win 7 Pro x64]
How can I convert point labels into regions, with the start of each region = the end of the previous?
The Tutorial https://manual.audacityteam.org/man/lab ... ml#editing says:
  • expand a point label into a region label by clicking and dragging either of its triangle handles
  • adjust the junction point where two labels meet by clicking and dragging their shared circle handle
but when I do this the regions do not merge into a "junction", instead they overlap (move to different rows in the label track).
Re: Join labels together: Make end of one the start of the next
Post by steve » Sat Dec 22, 2018 5:10 pm
That's quite tricky to do (as you have discovered), but in most cases you don't need to. For example, if you want the labels for "Export Multiple", then you can just use point labels instead.
tlm
Post by tlm » Mon Jan 13, 2020 12:06 pm
I too wanted to convert about 40 point labels into 20 corresponding region labels.
The realization that I wanted to do this came halfway through my labeling, so my label track had another 40 or so region labels after all the point labels.
Although I found no easy way to convert the earlier point labels to region labels, here is the work around I used which takes advantage of the yellow Audacity guides so that I didn't have to start over.
1) select the label track
2) copy and paste it to produce a duplicate label track right below it
3) select and delete all the point labels in the top label track
4) this shifts the existing region labels, so use the shift tool (option spacebar) to shift them back to where they belong
5) now take drag to define regions between point labels, taking advantage of the yellow Audacity guides
Post by steve » Mon Jan 13, 2020 12:24 pm
You can drag one of the label's "wings" with the mouse:
(Dragging the circle between the two "wings" moves the label)
Post by steve » Mon Jan 13, 2020 12:26 pm
You can delete a label track entirely, by clicking the [X] in the top left corner of the label track.
tlm
Post by tlm » Fri Jan 17, 2020 4:23 pm
Thanks for the tips
tlm
Post by tlm » Sat Feb 01, 2020 9:55 am
I found a solution to convert large numbers point labels into region labels (or vise-versa). I needed to do this for hundreds of labels, so I exported the label file (File-->Export-->Export Labels), did some editing in Excel, and then reimported the labels (File-->Import-->Import Labels). You just have to know how to work with spreadsheets/manipulate text files.
The key is to understand that the label files have this structure:
Point Labels:
0.34000 <tab> 0.34000 <tab> pointLabel1
0.86000 <tab> 0.86000 <tab> pointLabel2
1.53000 <tab> 1.53000 <tab> pointLabel3
2.97000 <tab> 2.97000 <tab> pointLabel4
Region Labels:
0.34000 <tab> 0.86000 <tab> regionLabel1
1.53000 <tab> 2.97000 <tab> regionLabel2
The image below shows what the above examples look like when imported into Audacity:
Screen Shot 2020-02-01 at 10.52.39 AM.jpg (83.9 KiB) Viewed 386 times
